Best Fit using the new GD&T engine
I’m not understanding how the new GD&T engine functions when doing a best fit. It’s putting the center of the bolt circle out in left field somewhere so when you look at the nominals they’re not even in the ballpark. I can go into the special functions and offset each feature back to where it’s supposed to be according to the print, but then the actuals really aren’t going to be respective of the best fit. What am I doing wrong?
In the picture below, you'll see Calypso thinks the center of the bolt pattern is located a couple inches above and slightly behind the highest bolt hole in the pattern. Consequently on the report (bottom picture), the nominals are way out in left field. The amount of deviation looks to be correct but when the program actually runs, we won't be able to tell which hole is off, what direction, and how much. The machinist won't have the required information to make the adjustments.
image.thumb.png.b19dc8a54d32b60c3e4fa242434ba761.pngimage.png.3fa3490d1a5a9dfcb02d1544b8abd495.png
Richard - I'll give that a try. Thanks.
Ivan - That would still be a pre-defined starting point. It would be the same as the original scenario except now it would be in a different spot. It still wouldn't be a true best fit. A best fit allows the bolt circle centerpoint to move around so that all of the error from all of the individual holes is minimized. That will give a better picture than just an average, or a location to a pre-defined point. Make sense? Did I explain that sufficiently? Hope that helped.
