[Ch...] Posted July 7 Share Posted July 7 Hello 🙂 I am just starting out with Calypso on an O-INSPECT machine. Could you tell me if the only way to duplicate a line (for example, to create a parallel line at a distance of 10 mm) is to copy it and modify its Y or X origin? Or is there a specific construction method for this? I ask because when I copy a "virtual" line, the camera moves to that location, but there is nothing there. If duplicating and modifying the origin is the only way, how do I include an unmeasured/dummy element in PiWeb? Thanks, and have a great day. Link to comment Share on other sites More sharing options...
[Ma...] Posted July 9 Share Posted July 9 I am not sure if there are any differences in UI of Calypso, but for nonmeasurable features you select it as "Theoretical feature" or if there is an feature, then use from construction menu ( offset plane, ... ) Link to comment Share on other sites More sharing options...
