[Ju...] Posted July 8 Share Posted July 8 is it worth it to upgrade from CALYPSO 2023 to 2026? Are you able to add MMC bonuses for the secondary or tertiary datums in the control frame. Can you visualize more than one features measured data simultaneously? In other words can I detect a problem without looking at a report. Is it possible to see a problem by just looking at the CAD model? What are other pros? Thanks! Link to comment https://qualityforum.zeiss.com/topic/26959-calypso-2026-software-upgrade/ Share on other sites More sharing options...
[Ri...] Posted July 8 Share Posted July 8 (edited) Absolutely. https://portal.zeiss.com/knowledge-base?id=3794258 https://portal.zeiss.com/academy/video-tube/imt/87496/Cee6NyY5M3YMmcbBrbzdSv You can also test the new GD&T engine in 2023 by activating the license, and then reloading Calypso. https://portal.zeiss.com/knowledge-base?id=2022494 Edited July 8 Link to comment https://qualityforum.zeiss.com/topic/26959-calypso-2026-software-upgrade/#findComment-152593 Share on other sites More sharing options...
[Br...] Posted July 8 Share Posted July 8 Hello Justin, When a new version or service pack gets released, there are always release notes that are online (download center) or even stored locally on your pc. C:\Program Files\Zeiss\CALYPSO 8.0\userinfo\release info Link to comment https://qualityforum.zeiss.com/topic/26959-calypso-2026-software-upgrade/#findComment-152607 Share on other sites More sharing options...
