[Lo...] Posted July 8 Share Posted July 8 Hello all, I attached a blue print below. The dimensions highlighted in yellow, I would like to inspect but am unclear where to look. Been looking through the profile section of Gear Pro I am missing it or I am in the wrong section. Was hoping someone could point me in the right direction. Thank you for any assistance. Regards, Lou Link to comment https://qualityforum.zeiss.com/topic/26961-semi-topping-hob/ Share on other sites More sharing options...
[Ün...] Posted July 8 Share Posted July 8 This is spline corner chamfer measurement; you can measure this with a Contour measuring device. 2 Link to comment https://qualityforum.zeiss.com/topic/26961-semi-topping-hob/#findComment-152601 Share on other sites More sharing options...
[Lo...] Posted July 8 Author Share Posted July 8 Please sign in to view this quote. Thank you. But can the highlighted feature be measured in Gear Pro and if so, is under the profile or which section is it under. Thanks, Lou Link to comment https://qualityforum.zeiss.com/topic/26961-semi-topping-hob/#findComment-152603 Share on other sites More sharing options...
[Ri...] Posted July 8 Share Posted July 8 You should be able to achieve this with the Tip Relief inside of the Profile characteristic. 1 Link to comment https://qualityforum.zeiss.com/topic/26961-semi-topping-hob/#findComment-152605 Share on other sites More sharing options...
[Ro...] Posted July 9 Share Posted July 9 Hi, as Richard mentioned you can try via relief evaluation. But typically a chamfer correction is compared to a relief much more bigger. It could happen that it´s not possible to visualize in the profile chart in a useful way. If so, you can try either with contour measurement equipment. Or separately with CALYPSO tools. 1 1 Link to comment https://qualityforum.zeiss.com/topic/26961-semi-topping-hob/#findComment-152615 Share on other sites More sharing options...
[Lo...] Posted July 14 Author Share Posted July 14 Thanks for the replies. I believe what I was La and Ca. In Gear Pro it's Ca and LCa. Picture is attached. Lou Link to comment https://qualityforum.zeiss.com/topic/26961-semi-topping-hob/#findComment-152869 Share on other sites More sharing options...
[Ro...] Posted July 14 Share Posted July 14 Yes, length of relief and amount of tip relief in this case Link to comment https://qualityforum.zeiss.com/topic/26961-semi-topping-hob/#findComment-152871 Share on other sites More sharing options...
