[Lo...] Posted 3 hours ago Share Posted 3 hours ago Hello all, I attached a blue print below. The dimensions highlighted in yellow, I would like to inspect but am unclear where to look. Been looking through the profile section of Gear Pro I am missing it or I am in the wrong section. Was hoping someone could point me in the right direction. Thank you for any assistance. Regards, Lou Link to comment Share on other sites More sharing options...
[Ün...] Posted 2 hours ago Share Posted 2 hours ago This is spline corner chamfer measurement; you can measure this with a Contour measuring device. 1 Link to comment Share on other sites More sharing options...
[Lo...] Posted 53 minutes ago Author Share Posted 53 minutes ago Please sign in to view this quote. Thank you. But can the highlighted feature be measured in Gear Pro and if so, is under the profile or which section is it under. Thanks, Lou Link to comment Share on other sites More sharing options...
[Ri...] Posted 26 minutes ago Share Posted 26 minutes ago You should be able to achieve this with the Tip Relief inside of the Profile characteristic. Link to comment Share on other sites More sharing options...
