Not able to measure true position on half cilinder
Goodmorning,
Im not able to measure the true position ABC.
It does fit a cylinder and it shows a diameter.
Why am I not able to retrieve an true position?
Do I have other ways to measure it?
You have to change a strandard into Geometry instead of ASME or ISO.
TP want's to use circular slices and if you don't have more than 180° then it fails ( i am not sure with angle number )
  • Like! 1
 what do you think about them getting rid of the feature being measured from the pop up menu?  We just switched to 2026 and it drives me nuts. You can see it missing in the above image.
 We just switched to 2026...your post made me simulate this...I've instructed our programmers to NOT set a standard b/c we always use geometry, and if we desire ASME we can do it at the feature level.  But you are correct, if you set the standard to ASME, then try to do an incomplete cylinder it fails...that is crazy, it worked fine in 2021.  They are really tightening up the rules.  Weird.
