subStr command not working after upgrading to 7.8
i have this program that was running on 6.8 version and now that we have upgraded to 7.8, i have nothing but issues with PCM
i have a file that contains point coordinates (file is attached)
  • i read the list
    • A = readListFile(MS_Curve_Points_Temp)                // read NX output
  • then i use subStr to seperate teh lines into individual string that i can easily phrase
    • D1 = subStr(A,1,1)
this was working up until we upgraded, now i am getting an error
can someone please tell what has happened and what can i do to address this issue
i tried to convert "A" to text, but it didn't help
Greeley appreciate all the help 🙂
13382673_10_fof_zeiss_20_ms_x_Temp.para
that worked, thank you very much for the help
i just checked few other programs that run the same/similar codes in 6.8 and below and substr seems to be working on those version
i personally don't know much coding and use whatever gives me the results 😅
your solution just saved my day and i am thankful
I must be missing something. When it's defined as: subStr(X,1,1), I'm under the impression it will only return the first character, not the first row/line.
For example.
Maybe someone smarter than me can explain why that works in your attached topic?
However, don't fix what's not broken.
