[Zo...] Posted 6 hours ago Share Posted 6 hours ago i have this program that was running on 6.8 version and now that we have upgraded to 7.8, i have nothing but issues with PCM i have a file that contains point coordinates (file is attached) i read the list A = readListFile(MS_Curve_Points_Temp) // read NX output then i use subStr to seperate teh lines into individual string that i can easily phrase D1 = subStr(A,1,1) this was working up until we upgraded, now i am getting an error can someone please tell what has happened and what can i do to address this issue i tried to convert "A" to text, but it didn't help Greeley appreciate all the help 🙂 13382673_10_fof_zeiss_20_ms_x_Temp.para Link to comment Share on other sites More sharing options...
[Ra...] Posted 5 hours ago Share Posted 5 hours ago I haven't used Calypso 6.8, but I'm surprised sub string ever worked in this case. instead of D1=subStr(A,1,1) Try: D1=getParameterNamed(A,1) That should give you the first row of the list. 1 Link to comment Share on other sites More sharing options...
[Zo...] Posted 3 hours ago Author Share Posted 3 hours ago Please sign in to view this quote. that worked, thank you very much for the help i just checked few other programs that run the same/similar codes in 6.8 and below and substr seems to be working on those version i personally don't know much coding and use whatever gives me the results 😅 your solution just saved my day and i am thankful Link to comment Share on other sites More sharing options...
