subStr command not working after upgrading to 7.8
i have this program that was running on 6.8 version and now that we have upgraded to 7.8, i have nothing but issues with PCM
i have a file that contains point coordinates (file is attached)
  • i read the list
    • A = readListFile(MS_Curve_Points_Temp)                // read NX output
  • then i use subStr to seperate teh lines into individual string that i can easily phrase
    • D1 = subStr(A,1,1)
this was working up until we upgraded, now i am getting an error
can someone please tell what has happened and what can i do to address this issue
i tried to convert "A" to text, but it didn't help
Greeley appreciate all the help 🙂
13382673_10_fof_zeiss_20_ms_x_Temp.para
I haven't used Calypso 6.8, but I'm surprised sub string ever worked in this case.
instead of D1=subStr(A,1,1)
Try: D1=getParameterNamed(A,1)
That should give you the first row of the list.
  • Thank you! 2
that worked, thank you very much for the help
i just checked few other programs that run the same/similar codes in 6.8 and below and substr seems to be working on those version
i personally don't know much coding and use whatever gives me the results 😅
your solution just saved my day and i am thankful
Glad I could help. I would be extremely cautious with the other programs using subStr though. If the context is similar to what you have shown above, I really can't fathom how they are working.
this is the portion of the code and in 6.8 worked flawlessly
i guess i got lucky with a glitch or something 😁
I must be missing something. When it's defined as: subStr(X,1,1), I'm under the impression it will only return the first character, not the first row/line.
For example.
Maybe someone smarter than me can explain why that works in your attached topic?
However, don't fix what's not broken.
i just ran it in two version to see what i get
it seems in my version, it doesn't see the "A" as string and still sees it as a list and returns "D1" also as a list
once i converted "A" to string it failed as you suggested
subStr must interact differently with a list than a string. But I get the same error from your first post when trying to parse through a list with subStr.
Maybe it has something to do with how the text file is encoded. 🤷‍♂️
