[Ni...] Posted July 9 Share Posted July 9 Hello, We encountered an odd issue on one of our workstations that operates Calypso that is connected to a CMM. One morning out of nowhere some of the text/font in our windows does not look like it should or does not look like all of the other workstations that we run Calypso on (3 online, 3 offline.) The issue primarily impacts the initial start window, the automatic stylus window, and a handful of other windows. I have tried changing the default font settings within the Calypso 'system settings: Environment' but it has no impact on correcting the issue regardless of whether we have "Calypso Standard" or "From System Settings" selected. I have also played around with the screen resolution, and a handful of other windows settings, but have run out of ideas as to how to fix the problem. I have even tried to install a different version of Calypso and the issue transfers over. If anyone has encountered the issue or may have any ideas on a system setting to change please let me know. The first two images below are what "normal" or what it "should" look like is. The second two images are the same windows from the problem machine. As you can see it is a bit of an issue in the automatic stylus changer window as the stylus names are covered up by the changer positions so you can't really tell what stylus system is in what position unless the operator is highly familiar with the systems and positions... "BAD/INCORRECT FONT/TEXT BELOW" Link to comment https://qualityforum.zeiss.com/topic/26975-calypso-fonttext-issue-on-a-single-workstation/ Share on other sites More sharing options...
[Za...] Posted July 9 Share Posted July 9 are fonts incorrect anywhere else on your PC? other software, Microsoft windows, etc...? Link to comment https://qualityforum.zeiss.com/topic/26975-calypso-fonttext-issue-on-a-single-workstation/#findComment-152687 Share on other sites More sharing options...
[Ab...] Posted July 10 Share Posted July 10 (edited) Hello You can go to Extras>Settings>Environment>Font and see if the font is system setting or Calypso standard. if its system setting you can change to Calypso standard and see if that would fix it Edited July 10 Link to comment https://qualityforum.zeiss.com/topic/26975-calypso-fonttext-issue-on-a-single-workstation/#findComment-152731 Share on other sites More sharing options...
[Ni...] Posted July 10 Author Share Posted July 10 (edited) Please sign in to view this quote. Hello Zak, Not that I have noticed but do suspect it is possibly a windows issue as everything looked fine for the first 6+ months of using the workstation, but then one Monday morning I loaded and launched everything like normal to find Calypso text/font not looking right. Edited July 10 Link to comment https://qualityforum.zeiss.com/topic/26975-calypso-fonttext-issue-on-a-single-workstation/#findComment-152753 Share on other sites More sharing options...
[Ni...] Posted July 10 Author Share Posted July 10 Please sign in to view this quote. Hello Abbas, Yes, I have tried flipping back and forth between those two settings, but it has no effect on the "bad" Calypso windows. Link to comment https://qualityforum.zeiss.com/topic/26975-calypso-fonttext-issue-on-a-single-workstation/#findComment-152755 Share on other sites More sharing options...
