[Du...] Posted July 9 Share Posted July 9 Ive been tasked with adding and subtracting dN from one another and the sum of the two dN must fall within a tolerance. So my question is with an hour or two of research already, how do you add or subtract dN of 2 surface points? Also adding a tolerance to it for the requirements. TIA Link to comment https://qualityforum.zeiss.com/topic/26977-expressions-to-do-basic-math/ Share on other sites More sharing options...
[Ma...] Posted July 10 Share Posted July 10 If you want to have such calculations, you have to add those measurements into variables at top of a user defined measurement window. Then in formula you use "A.actual + B.actual" Same thing can be with .nominal at nominal section. Tolerance should be there also. Link to comment https://qualityforum.zeiss.com/topic/26977-expressions-to-do-basic-math/#findComment-152705 Share on other sites More sharing options...
