[Cl...] Posted July 13 Share Posted July 13 Can i use "Rotate to distance to the +X axis:" in case of the attached drawing ? Link to comment Share on other sites More sharing options...
[Ma...] Posted July 13 Share Posted July 13 I would use "Same deviation" and fill both coordinates - otherwise no. Result of TP will be the same if you just fill ABC into datums. Nominal coordinated will be taken from feature. 1 Link to comment Share on other sites More sharing options...
[Cl...] Posted July 13 Author Share Posted July 13 (edited) Hello Thank you for your answer in, I also try to find an answer with Microsoft AI "Copilot" a i ask to put anything in a PDF. Ar this correct? please let me know your opinion Calypso_GDT_Datum_Alignment_Summary_With_Image.pdf Edited July 13 Link to comment Share on other sites More sharing options...
