Recording tolerance changes and running script on many programs
Running 2026 Zeiss Inspect
When you record a tolerance change on a Diameter or Distance and then run that script it will change the tolerance and nominal size.
When you record a profile tolerance change and run that script it will not change the tolerance.
When you record a position tolerance change and run that script it will not change the tolerance, but it will allow you to change the True Position location.
Odd behavior...There are many times we have similar programs with the same feature names and I like to run a script to automate changing things over many programs.
I don't have 26, but i would say - explore that recorded script. Certainly you can remove some of it's content to fulfill your goals.
 Interesting. Can you post the code for review? How are your programs set up (for example, is it one part or many stages)?
Yall may have misunderstood me.
Let's assume you have 10 programs that are all identical except they are different parts numbers....now the customer changes the tolerances.
You can open all 10 programs and change the tolerances 1 by 1, or you can record yourself doing it once, then loop thru all programs and save them.
When you record a tolerance change for a diameter or distance it works when you play the script,  But if you record and run a tolerance change on a profile or position  check it won't change it at all.
I found that using "edit_creation_parameters" is more uniformly than using "edit_properties"
Here is example of editing creation parameters for diameter of a circle and TP of a circle with editing only tolerance
gom.script.sys.edit_creation_parameters (
	element=gom.app.project.inspection['Kružnice 1.Ø'],
	tolerance={'lower': -0.5, 'tolerance_type': 'two_sided_center', 'upper': 0.6})
	element=gom.app.project.inspection['Kružnice 1.Poloha'],
	tolerance=1.2)
Here is example of edit properties - there is tolerance named differently - tol_dimension / tol_gdat
gom.script.sys.edit_properties (
	data=[gom.app.project.inspection['Kružnice 1.Ø']],
	tol_dimension_lower=-0.9,
	tol_dimension_lower_warn=0.0,
	tol_dimension_upper=0.9,
	tol_dimension_upper_warn=0.0,
	tol_dimension_use_lower=True,
	tol_dimension_use_upper=True,
	tol_dimension_use_warn_level=False,
	tol_template='')
	data=[gom.app.project.inspection['Kružnice 1.Poloha']],
	tol_gdat_upper=1.4,
	tol_template='')
  • Like! 1
That is what I use to bulk edit dimensions:
    element=gom.app.project.inspection['ITEM_125_2_TP'],
    specification={
'combination_specification': 'SZ',
'datum_system': {
'datum_element': gom.app.project.actual_elements['A']
'dimension_reference': gom.app.project.inspection['CYL_125.GG'],
'elements': [gom.ActualReference (gom.app.project.inspection['CYL_125'])],
'material_condition': '(M)',
'theoretically_exact_dimensions': {
'position_1': 1.528034632e-06
'use_bonus_tolerance': True,
'use_pure_geometry': True,
'zone_modifier': 'cylindrical',
'zone_size': 10.0
    tolerance=10.0)
You can see I set the tolernace to 10mm..but the feature after running this script will not change the tolerance.  Profiles and Position tolerances won't take the change, but distances and diameters will accept the change.
I have a problem on 2025 version. Are you using 2026?
I was trying every possible combination for achieving same python code, but i can not replicate your code.
Is your code reporting errors?
RequestError: GAPP-0013: Command parameter error.
The parameter specification is unknown.
I am using 2026.  My code executes and works, but will not updated the tolerance for GDT checks.  2021 did not either.
