[Sa...] Posted 22 hours ago Share Posted 22 hours ago Hi everyone For some time now I haven't been able to connect to the sensor. I even tried uninstalling the software and it's still the same error. Please, if anyone has the solution. I'm attaching pictures with the errors. Link to comment Share on other sites More sharing options...
[Ma...] Posted 21 hours ago Share Posted 21 hours ago I think we have there actual IP address displayed from device. You can try to reboot ATOS. We also had a problem with loose connection. Link to comment Share on other sites More sharing options...
[Sa...] Posted 20 hours ago Author Share Posted 20 hours ago Please sign in to view this quote. I tried and it doesn't work, the connection is enabled, I have all the IPs, and the sensor's IP has restrictions because of the internal network here, and that's the problem, but it worked before. Thanks for the reply! Link to comment Share on other sites More sharing options...
[Ma...] Posted 20 hours ago Share Posted 20 hours ago When we turn on ATOS, then it projects it's IP - this is what we have at hardware setup. Link to comment Share on other sites More sharing options...
[Ma...] Posted 4 hours ago Share Posted 4 hours ago So our setup is like this: bottom IP is projected from ATOS before connecting. Link to comment Share on other sites More sharing options...
