[Ma...] Posted July 16 Share Posted July 16 In the new custom elements feature (https://zeiss.github.io/zeiss-inspect-app-api/2026/howtos/custom_elements/custom_nominals_actuals.html), is it possible to create an element based on a point selection in the 3D view? For example, let's say I want to implement a RANSAC based fitting circle. I want the user to select points from a cross-section, rather than simply providing the whole section element, which I will then run RANSAC on. Is that possible with the current 2026 software? Thanks! Link to comment https://qualityforum.zeiss.com/topic/27031-custom-elements-extension-api-with-pointmesh-selection/ Share on other sites More sharing options...
[Ti...] Posted July 20 Share Posted July 20 Hello, in general it is possible to access the current point selection of any surface element in Zeiss Inspect using element.selection.coordinate instead of element.data.coordinate More details are available in the documentation (Frequently asked questions — App Development Documentation) It is however not possible to store or restore this selection when recalculating the custom element, because commands can’t be executed from inside a service. This means that the element will not be parametric. 1 Link to comment https://qualityforum.zeiss.com/topic/27031-custom-elements-extension-api-with-pointmesh-selection/#findComment-153103 Share on other sites More sharing options...
