[Ba...] Posted July 17 Share Posted July 17 I am trying to measure the thickness at a few locations on the web of an H-beam specimen. I would like to create measurement points by entering their coordinates. Since these coordinates are idealized, the points will not necessarily lie exactly on the web surface. Is there a way to project these points onto the web surface (or snap them to the nearest surface) and then obtain the local thickness at those projected locations? I am very new to the software, so if you could explain the steps in detail, I would really appreciate it. Thanks! Link to comment https://qualityforum.zeiss.com/topic/27033-cant-measure-the-thicknesses-on-the-web/ Share on other sites More sharing options...
[Ma...] Posted July 17 Share Posted July 17 If you select mesh, you can create evenly distributed points, which can be used for material thickness. Construct -> Distance -> Material distance Construct -> Point -> Equidistant points -> Surface points evenly Using CAD model would be better option 2 Link to comment https://qualityforum.zeiss.com/topic/27033-cant-measure-the-thicknesses-on-the-web/#findComment-153053 Share on other sites More sharing options...
