cant measure the thicknesses on the web
I am trying to measure the thickness at a few locations on the web of an H-beam specimen. I would like to create measurement points by entering their coordinates. Since these coordinates are idealized, the points will not necessarily lie exactly on the web surface.
Is there a way to project these points onto the web surface (or snap them to the nearest surface) and then obtain the local thickness at those projected locations?
I am very new to the software, so if you could explain the steps in detail, I would really appreciate it. Thanks!
If you select mesh, you can create evenly distributed points, which can be used for material thickness.
Construct -> Distance -> Material distance
Construct -> Point -> Equidistant points -> Surface points evenly
Using CAD model would be better option
