[Ka...] Posted July 17 Share Posted July 17 Moin, Wir haben mehrere PiWeb Protokolle für eine Messung. Z.B. Fertigung, Kunde, Übersicht ,Kurzform, Merkmalsgruppe X usw. Manche werden nur angezeigt, manche wiederum als pdf abgelegt. In der Endung zu *.pdf wird von CALYPSO/PiWeb automatisch die Nummer des protokolls aus der Auswahl "Definition Mehrfachprotokolle" hinzugefügt. Am Ende des Dateinamens wird dann "(1).pdf" für das erste Protokoll und "*(3).pdf" für das dritte Protokoll als Endung angefügt. Gibt es eine Variable in PiWeb die diesen index zur Verfügung stellt? Danke und Gruß Karsten Link to comment https://qualityforum.zeiss.com/topic/27035-welche-variable-f%C3%BCr-protokoll-nummer/ Share on other sites More sharing options...
[Ma...] Posted July 17 Share Posted July 17 I did not find anything. No info in Calypso program and no info in PiWeb. There is no text "PiWeb reporting" so it can not be renamed even manually Link to comment https://qualityforum.zeiss.com/topic/27035-welche-variable-f%C3%BCr-protokoll-nummer/#findComment-153047 Share on other sites More sharing options...
[Ka...] Posted July 17 Author Share Posted July 17 Please sign in to view this quote. Hi Martin; thanks for your research... No documentation. It took me a few attempts to even work out that the file index ´(x).pdf’ refers to the order of the defined protocols. So I need to open a call to Zeiss PiWeb experts in hope there is an (undocumented) feature... 1 Link to comment https://qualityforum.zeiss.com/topic/27035-welche-variable-f%C3%BCr-protokoll-nummer/#findComment-153049 Share on other sites More sharing options...
[Do...] Posted July 20 Share Posted July 20 Hi, No, PiWeb does not provide a variable for the automatically generated protocol index. The index "(1)", "(2)", "(3)", etc. is only appended to the filename during PDF export by CALYPSO/PiWeb and is not available within the protocol templates. Solution: If you need the index in the protocol, you can define a custom variable and maintain it manually. What is your specific use case? Link to comment https://qualityforum.zeiss.com/topic/27035-welche-variable-f%C3%BCr-protokoll-nummer/#findComment-153077 Share on other sites More sharing options...
[Ka...] Posted July 27 Author Share Posted July 27 Hello Dogan, Sorry, I was out of Office 😞 We use the "Action → Lock Measurement" feature to allow the user to enter a value in the "Approval Status" database field after the measurement. However, by this point the PDF files have already been generated and do not contain any indication that the measurement has been locked. We therefore initiate a further action by running a script via “Action → Open File”. This script will then rename the generated file so that it is clear that this measurement has been locked. However, to locate the file unambiguously, I need the index that CALYPSO appends to the file name. If the PiWeb log is listed under index 3, I need to know that I must look for the file extension *(3).pdf. An internal variable is of no use to me unless CALYPSO informs PiWeb of the index used to create PDF files for the current PiWeb form. Link to comment https://qualityforum.zeiss.com/topic/27035-welche-variable-f%C3%BCr-protokoll-nummer/#findComment-153445 Share on other sites More sharing options...
[Do...] Posted August 5 Share Posted August 5 Hi, Instead of automatically generating the PDF document after the CNC process, you could use the AcceptProtocol. You could assign an additional action to the existing “Block Measurement” button to export the PDF file with the desired filename. Link to comment https://qualityforum.zeiss.com/topic/27035-welche-variable-f%C3%BCr-protokoll-nummer/#findComment-153894 Share on other sites More sharing options...
