Error preventing scans. MPROJ-0018
Good morning/evening
When trying to perform an inspection, i keep getting this error. Every element in the project is recalculated besides some alignments, but can't perform those without a scan. Scan works normally if all measurement positions are highlighted and right clicking "measure at selected positions". Would like to resolves this issue as the program is scanning through four parts with four different scans that are all dependent on the Photogrammetry series which is always performed first. any idea as to what the issue could be?
Specifications:
Zeiss Inspect 2026 pro
Photogrammetry>Scan 1> Scan 2> Scan 3> Scan 4
ATOS 5
5130 Scanbox with Co-bot
Kind regards,
-Yager
https://qualityforum.zeiss.com/topic/27049-error-preventing-scans-mproj-0018/
Thank you! Found the actual issue was the setting "Do you want to check if there is enough scan data for your elements?" causing a conflict with the existing alignment process. Hopefully this can help someone out in the future! it's under acquisition template
  • Like! 1
