[Zo...] Posted July 21 Share Posted July 21 For an unknown reason Calypso cannot connect to my CMM< a Contura that I've been connecting to for the last 6 years with no issues. We no longer have a service contract so I cannot call Zeiss for remote help, but I am, hoping someone here can help me figure out what could cause the disconnect and how to reconnect. When I turn on the CMM and the drive is on, I am getting the following message, see attached. Any help is greatly appreciated. Link to comment Share on other sites More sharing options...
[No...] Posted July 21 Share Posted July 21 (edited) First check the usual suspects: Network card(s) in your PC (settings, IP address, card correctly seated in PC slot?) Network cable to CMM (seated correctly?, undamaged?) CMM settings in Calypso (Calypso uses a standard IP address, which I don't remember out of my head - maybe others can fill in) Do you happen to have a network switch or any other inbetween device between CMM and PC? If so, check if it's ok. Something related that I surely forgot... I all else fails, a faulty CMM controller should also be considered. Edited July 21 2 Link to comment Share on other sites More sharing options...
[Ca...] Posted July 21 Share Posted July 21 Hello - Here is an article that will walk you through many of the checks outlined above: https://portal.zeiss.com/knowledge-base?query=connection&id=454224 1 Link to comment Share on other sites More sharing options...
[Zo...] Posted July 21 Author Share Posted July 21 I followed the steps in the link and found that the "CMM Network" connection on my PC was disabled, for reasons unknown at this time. I re-enabled it and Calypso connected as usual, it seems to be back to normal. Thank you enormously. 2 Link to comment Share on other sites More sharing options...
