[Jo...] Posted July 21 Share Posted July 21 Hello all I recently ran into something strange. I have a program that evaluates the profile of a freeform surface relative to a datum (cylinder). I changed the datum to a point and got no result. After I switched the datum scheme back, I got wildly different results. The initial result was about 0.55 and the final result was 0.016. Has anyone else ran into this? Is there something I doing incorrectly? Link to comment https://qualityforum.zeiss.com/topic/27055-profile-re-evaluation/ Share on other sites More sharing options...
[Jo...] Posted July 21 Share Posted July 21 Any custom settings you made to the feature selected inside the characteristic will be lost when you reassign it. You may have had an alternate evaluation setting on that datum inside of that characteristic. (Right click on datum feature icon to adjust settings inside of a characteristic) Calypso should automatically set the ideal evaluation settings according to which GD&T mode you are set to ASME/ISO Link to comment https://qualityforum.zeiss.com/topic/27055-profile-re-evaluation/#findComment-153147 Share on other sites More sharing options...
[Ma...] Posted July 21 Share Posted July 21 (edited) Sometimes filling datums not fully can lead to those situations, where recalculations shows another value. Edited July 21 Link to comment https://qualityforum.zeiss.com/topic/27055-profile-re-evaluation/#findComment-153161 Share on other sites More sharing options...
[Jo...] Posted July 24 Author Share Posted July 24 Please sign in to view this username. that looks like the cause. When I repopulate the datum field, Calypso chooses an LSQ evaluation when it was Outer Tangential originally. Seems strange because I have Outer Tangential as the default setting in Form Datum, but I guess now I know 1 Link to comment https://qualityforum.zeiss.com/topic/27055-profile-re-evaluation/#findComment-153423 Share on other sites More sharing options...
