[Zo...] Posted July 22 Share Posted July 22 not sure if this is the right place to post this question (Mods feel free to relocate) I do a lot of offline programming and use notepad++ for ease of use and formatting unfortunately, when doing the same with Calypso, I lose the colour coding with other platforms, like Renishaw's Modus or similar, I found an .xml file that i could import into Notepad++ as user defined language I had built up one myself years ago that was very close, but my pc died and i lost all my settings I am sure one of you geniuses here has something that can share, please and thank you 🙂 Link to comment https://qualityforum.zeiss.com/topic/27069-notepad/ Share on other sites More sharing options...
[Ra...] Posted July 22 Share Posted July 22 Are you looking for this? There is an option to load settings, but I doubt it can load .xml files but you can try. Link to comment https://qualityforum.zeiss.com/topic/27069-notepad/#findComment-153245 Share on other sites More sharing options...
[Zo...] Posted July 22 Author Share Posted July 22 Please sign in to view this username. i am looking for setup to load into notepad++ basically i want my editing tool look like PCM editor in Calypso with all the color coding Link to comment https://qualityforum.zeiss.com/topic/27069-notepad/#findComment-153247 Share on other sites More sharing options...
[Ch...] Posted July 22 Share Posted July 22 There is a 'smalltalk' coding option, it's close but not exact. I did try to build a custom one awhile back, I think I uploaded something on the forums... when I find I'll share but it's not perfect. 1 Link to comment https://qualityforum.zeiss.com/topic/27069-notepad/#findComment-153249 Share on other sites More sharing options...
[Zo...] Posted July 23 Author Share Posted July 23 Please sign in to view this username. I hope you find it 🤞 "smalltalk" doesn't know any of the commands and mostly uses different colour scheme 1 Link to comment https://qualityforum.zeiss.com/topic/27069-notepad/#findComment-153281 Share on other sites More sharing options...
[No...] Posted July 23 Share Posted July 23 Please sign in to view this quote. This one perhaps? 2 Link to comment https://qualityforum.zeiss.com/topic/27069-notepad/#findComment-153309 Share on other sites More sharing options...
[Ch...] Posted July 23 Share Posted July 23 well no luck finding it, I searched through my attachments, posts and the forums. I believe I shared an .xml on the old forums, it was pretty close - but that was before AI. I think you could easily vibe code your own one with AI. I did post on Notepad ++ forums about this. The smalltalk syntax highlighting is like 17yrs old and has not been changed in a very long time. Link to comment https://qualityforum.zeiss.com/topic/27069-notepad/#findComment-153311 Share on other sites More sharing options...
[Ch...] Posted July 23 Share Posted July 23 (edited) Please sign in to view this quote. yes good find Norbert ! I swore I attached an .xml, I'll search my files but I have a feeling it is gone, since migrating jobs, etc. Ah, I see , couldn't upload the .xml - so I posted the code; give it a shot. If you get it figured out, feel free to share with everyone ! good luck !! Edited July 23 1 Link to comment https://qualityforum.zeiss.com/topic/27069-notepad/#findComment-153313 Share on other sites More sharing options...
[Jö...] Posted July 30 Share Posted July 30 (edited) Hallo Zolfagari, du kannst doch bei Notepad++ unter Language verschieden Programmiersprachen einstellen. Vielleicht ist ja eine dabei wo due verwenden kannst, und kannst sie dann noch farblich anpassen. Edited July 30 1 Link to comment https://qualityforum.zeiss.com/topic/27069-notepad/#findComment-153672 Share on other sites More sharing options...
[Ri...] Posted August 1 Share Posted August 1 Please sign in to view this quote. I am trying to use your xml code (From your link), but it crashes Notepad ++ every time I apply it. By crashing, Notepad ++ simply closes. Any hints or tips? Link to comment https://qualityforum.zeiss.com/topic/27069-notepad/#findComment-153790 Share on other sites More sharing options...
[Mi...] Posted August 3 Share Posted August 3 (edited) I have a version that recognizes all commands from the function list, comments and operators. As far as I know, using a UDL makes it impossible to recognize a parameter, such as para1=2, so these are still black. CALYPSO-PCM.xml Edited August 3 1 1 Link to comment https://qualityforum.zeiss.com/topic/27069-notepad/#findComment-153802 Share on other sites More sharing options...
[Ri...] Posted August 3 Share Posted August 3 Please sign in to view this quote. This one works without crashing Notepad ++. 1 Link to comment https://qualityforum.zeiss.com/topic/27069-notepad/#findComment-153808 Share on other sites More sharing options...
