Notepad++
not sure if this is the right place to post this question (Mods feel free to relocate)
I do a lot of offline programming and use notepad++ for ease of use and formatting
unfortunately, when doing the same with Calypso, I lose the colour coding
with other platforms, like Renishaw's Modus or similar, I found an .xml file that i could import into Notepad++ as user defined language
I had built up one myself years ago that was very close, but my pc died and i lost all my settings
I am sure one of you geniuses here has something that can share,
please and thank you 🙂
Are you looking for this? There is an option to load settings, but I doubt it can load .xml files but you can try.
 i am looking for setup to load into notepad++
basically i want my editing tool look like PCM editor in Calypso with all the color coding
There is a 'smalltalk' coding option, it's close but not exact. I did try to build a custom one awhile back, I think I uploaded something on the forums... when I find I'll share but it's not perfect.
  I hope you find it 🤞
"smalltalk" doesn't know any of the commands and mostly uses different colour scheme
well no luck finding it, I searched through my attachments, posts and the forums.
 I believe I shared an .xml on the old forums, it was pretty close - but that was before AI.
I think you could easily vibe code your own one with AI.
 I did post on Notepad ++ forums about this. The smalltalk syntax highlighting is like 17yrs old and has not been changed in a very long time.
yes good find Norbert ! I swore I attached an .xml, I'll search my files but I have a feeling it is gone, since migrating jobs, etc.
Ah, I see , couldn't upload the .xml - so I posted the code; give it a shot. If you get it figured out, feel free to share with everyone ! good luck !!
Hallo Zolfagari,
du  kannst doch bei Notepad++ unter Language verschieden Programmiersprachen einstellen. Vielleicht ist ja eine dabei wo due verwenden kannst, und kannst sie dann noch farblich anpassen.
I am trying to use your xml code (From your link), but it crashes Notepad ++ every time I apply it.
By crashing, Notepad ++ simply closes.
Any hints or tips?
I have a version that recognizes all commands from the function list, comments and operators. As far as I know, using a UDL makes it impossible to recognize a parameter, such as para1=2, so these are still black.
CALYPSO-PCM.xml
  • Thank you! 1
