[Ma...] Posted July 23 Share Posted July 23 I have a part that is basically a half sphere that is hollow. I need the ID and OD. I have never worked with spheres. How would I do the base alignment so that the machine can reliabley find the part to measure? Link to comment https://qualityforum.zeiss.com/topic/27073-sphere-issues/ Share on other sites More sharing options...
[Ma...] Posted July 23 Share Posted July 23 Well you can just fill XYZ from a sphere and nothing else. But i would fill start alignment and take granite scan and direction from that. Then you can run base alignment normally, but you just select start alignment from alignments list ( usually you have there "Existing alignment" ) 1 Link to comment https://qualityforum.zeiss.com/topic/27073-sphere-issues/#findComment-153321 Share on other sites More sharing options...
[Ma...] Posted July 23 Author Share Posted July 23 Please sign in to view this quote. I didn't even think of a start alignment. Thanks for that. Link to comment https://qualityforum.zeiss.com/topic/27073-sphere-issues/#findComment-153323 Share on other sites More sharing options...
