[is...] Posted July 23 Share Posted July 23 hi all, any idea how to tackle this? distance over ball on torus. any help will be much appreciated. thanks in advance. Link to comment https://qualityforum.zeiss.com/topic/27081-distance-over-ball-on-torus/ Share on other sites More sharing options...
[Ke...] Posted July 23 Share Posted July 23 You may have luck with "Circle in Contour Fit" if you have Curve; otherwise, you may need to purchase 15mm probes and use self-centering points Link to comment https://qualityforum.zeiss.com/topic/27081-distance-over-ball-on-torus/#findComment-153339 Share on other sites More sharing options...
[is...] Posted July 23 Author Share Posted July 23 Hi Keith, using 15mm styli, probe midpoint + actual probe radius in result element is that correct? just to confirm thanks. 1 Link to comment https://qualityforum.zeiss.com/topic/27081-distance-over-ball-on-torus/#findComment-153341 Share on other sites More sharing options...
[Ke...] Posted July 24 Share Posted July 24 Please sign in to view this quote. Yes, indeed 1 Link to comment https://qualityforum.zeiss.com/topic/27081-distance-over-ball-on-torus/#findComment-153391 Share on other sites More sharing options...
