[Je...] Posted July 23 Share Posted July 23 I'm interested to hear from users regarding Zeiss's M.A.S.S. (Multi Application Sensor System) swappable sensor technology on Contura CMMs. Do you use multiple probe types (XXT, DotScan, ViScan, LineScan, VAST, etc.) on your Contura CMM? If so, how well does it work for you? Sidenote #1: but have any of you used ViScan on an RDS? I wonder how effective this 2D camera on an articulating sensor has been for users. Sidenote #2: Have any of you used the new Compact XXT? How does it compare in performance to the legacy TL3 XXT? Thanks for your feedback. 1 Link to comment https://qualityforum.zeiss.com/topic/27083-zeiss-contura-mass-tech-sensor-questions/ Share on other sites More sharing options...
[Wo...] Posted July 24 Share Posted July 24 I'm very interested in the new compact XXT for the Contura we have. I hope they will have it at IMTS in Chicago this year. We do swap sensors on our oldest Accura between XT and RDS. Very simple process - no need to shut down the CMM or Calypso. 1 Link to comment https://qualityforum.zeiss.com/topic/27083-zeiss-contura-mass-tech-sensor-questions/#findComment-153367 Share on other sites More sharing options...
[Ri...] Posted July 24 Share Posted July 24 (edited) I now have XTR and XXT sensors, swapping takes minutes to complete. As of today, I do not mix sensors in a single program, I don't even know if that is possible or sensible. As for Probe racks, I designed a custom rack that sits above the XTR MSR 2.0 system (I have posts I the forum on this design). The design works as intended. In the past I worked on system that had an XT Gold, XTR, XXT, Dotscan and Viscan. The XXT, Dotscan and Viscan are all on the RDS head while the XT and XTR were of course a different system. This place was at the time a Zeiss vendor, I had access to all the goodies you could imagine, and it was glorious. Scroll through the posts to see the custom rack. Edited July 24 2 Link to comment https://qualityforum.zeiss.com/topic/27083-zeiss-contura-mass-tech-sensor-questions/#findComment-153373 Share on other sites More sharing options...
[Ri...] Posted July 24 Share Posted July 24 We have a Contura with an RDS that has both the XXT and DotScan, we also have it setup for an XTR. Great system, with no issues swapping heads. I even like that the Contura/Micura now have the ability to have a Rotary Table - makes gear inspections a breeze now. 1 Link to comment https://qualityforum.zeiss.com/topic/27083-zeiss-contura-mass-tech-sensor-questions/#findComment-153395 Share on other sites More sharing options...
[Br...] Posted July 25 Share Posted July 25 I'm currently running a 2026 Spectrum with a 5° incremental RDS and what I believe is the redesigned TL3 (the black one with the much smaller head). From what I can tell, it seems to be the same probe overall, but I keep running into one major drawback: the back of the probe head is significantly larger than the front. With the previous TL3 design, I could articulate to B90° and swing over features without any issues. The larger backside on the new design makes clearance much more difficult and has forced me into some pretty awkward fixturing situations. A lot of the parts I inspect are easily fixtured in a standard machinist vise, but with the new probe head I can no longer clear the tightening end of the vise like I could before. It just means rethinking fixturing for jobs that used to be straightforward. It's not a dealbreaker—just something I've had to adapt to with the new design, and something others may want to keep in mind if they're considering the new TL3. Also, if sensor matching eventually allows multiple sensors to be used within a single program, that would be a huge improvement. It would make workflows much more flexible and eliminate the need to maintain separate programs for different sensor configurations. And, to be a bit of a metrology nerd, I think that would be pretty cool. Let me know if what I'm describing with the new TL3 lines up with your experience. I'm newer to this thread, so I just want to make sure I'm explaining it clearly. This forum has been an incredibly helpful resource for me; and I would hate to confuse people. Brendan Pitzen 2 Link to comment https://qualityforum.zeiss.com/topic/27083-zeiss-contura-mass-tech-sensor-questions/#findComment-153425 Share on other sites More sharing options...
[Wo...] Posted July 27 Share Posted July 27 Please sign in to view this quote. That's really good info, thanks! 1 Link to comment https://qualityforum.zeiss.com/topic/27083-zeiss-contura-mass-tech-sensor-questions/#findComment-153463 Share on other sites More sharing options...
[Jo...] Posted July 27 Share Posted July 27 I had not noticed that the center of rotation has changed! That geometry would have some downsides for us too. Bummer was really excited about a "shorter XXT" Link to comment https://qualityforum.zeiss.com/topic/27083-zeiss-contura-mass-tech-sensor-questions/#findComment-153503 Share on other sites More sharing options...
[Je...] Posted July 27 Author Share Posted July 27 Please sign in to view this username. , I'm wondering if perhaps there are performance upsides to the new design. The legacy XXT is prone to acting like a fulcrum, especially with longer stylus systems. I wonder if the newer design could mitigate some of this. 4 Link to comment https://qualityforum.zeiss.com/topic/27083-zeiss-contura-mass-tech-sensor-questions/#findComment-153539 Share on other sites More sharing options...
[Je...] Posted July 29 Share Posted July 29 The MASS sensor is actually the ideal setup for applications requiring the ViScan/LineScan/DotScan sensor. It allows the use of the more robust active VAST sensor where needed and flexibility to allow for alternate sensor configurations where needed. There are a great many ZEISS users that utilize the MASS system to take advantage of an VAST/XT or XTR, having a rotary table and still have the capability to use an optics sensor (IE - LineScan now with full scanning during RT rotation). LineScan is probably the most common MASS VAST + RDS combo. Note: swapping the sensor platforms out (via dovetail) requires powering the drives down and changing machine tabs within CALYPSO....but... stay tuned 🙂 The COMPACT XXT is essentially the same hardware as the TL3 with a different rotational point to conserve measuring volume. Same sensor plates and compatible between measurement plans without substantial adaptation. The intent is to increase measuring volume on smaller machines (think SPECTRUM 7/7/6) by shortening the sensor protrusion. This gains ~150mm of volume in every axis without having to adapt an "L" probe and use the sensor in the -Z orientation to get full X/Y volume use. Pick the configuration that works for you. This adds more options and flexibility to meet your specific requirements. 3 Link to comment https://qualityforum.zeiss.com/topic/27083-zeiss-contura-mass-tech-sensor-questions/#findComment-153664 Share on other sites More sharing options...
[Je...] Posted July 29 Author Share Posted July 29 Thanks, Please sign in to view this username. . I appreciate your feedback on MASS and the Compact XXT, especially the subtle hint to a possible effort to accomodate live sensor swapping without power down. If such an endeavor was successful, it would be a huge value add. It sounds like the Compact XXT may not be fully available in US markets yet, per our local distributor, but I am interested in trying one out as soon as they're available. Thanks again for weighing in on this! Link to comment https://qualityforum.zeiss.com/topic/27083-zeiss-contura-mass-tech-sensor-questions/#findComment-153666 Share on other sites More sharing options...
[Ro...] Posted July 29 Share Posted July 29 Please sign in to view this username. The Compact XXT has been available in the US Market since January of this year. We've sold plenty systems configured with it and as Jeff mentioned, it's an ideal option when purchasing a system with a 7/7/6 measuring volume. 1 Link to comment https://qualityforum.zeiss.com/topic/27083-zeiss-contura-mass-tech-sensor-questions/#findComment-153668 Share on other sites More sharing options...
[Ch...] Posted July 29 Share Posted July 29 Please sign in to view this quote. OMG, is it christmas, are you kidding us ? Hot swapping sensors automatically in the rack, without losing accuracy ? 😅😉 I'm speculating of course .... 2 Link to comment https://qualityforum.zeiss.com/topic/27083-zeiss-contura-mass-tech-sensor-questions/#findComment-153670 Share on other sites More sharing options...
