Editing PiWeb reports...
I need to add an Export Controlled Information clause to BACK of the last page in my PiWeb printouts, so it's still identifiable as sensitive information if the packet is face down.  This last page back needs to be blank except for this statement.
How can I set up PiWeb to print this on the back of the last page?
https://qualityforum.zeiss.com/topic/27087-editing-piweb-reports/
I'm sorry Richard, I'm not understanding you.  My current part has a report that's 4 pages total.  The last page in the packet, needs to have a statement printed on the back of it, not on the front side with the data.  So when I'm done, the report has a cover sheet with the statement (which I've done) and the back of the last page has the statement.
No matter which side of the packet you see, all you see are the export restriction clauses.
https://qualityforum.zeiss.com/topic/27087-editing-piweb-reports/#findComment-153399
Since you already have a cover sheet for the front, couldn't you just print that twice and have the operator staple it to the back facing backwards?
If the doesn't work for you, then there are virtual print manager software that can do this I think.  For example, you can tell it to concatenate a document to the front and back of every thing printed.  Something like [cover page] + [CMM Report] + [cover page].    Stuff like FinePrint or Print2PDF.
I think you're going to have better luck doing this outside of PiWeb.
https://qualityforum.zeiss.com/topic/27087-editing-piweb-reports/#findComment-153407
Posted (edited)
Chad,
I don't hate this idea, but I don't think it will satisfy the requirement.
There's a bit of this that doesn't make sense to me.  As far as I know, the customer doesn't get printed copies of our reports.  They only get PDF's or Excel files, or text files, so what's the point of having a coversheet, on the rear page of a packet, that doesn't get printed?
Not to speak poorly of a customer requirement, but if I understood more, I'd be better prepared to satisfy the requirement.
Edited
https://qualityforum.zeiss.com/topic/27087-editing-piweb-reports/#findComment-153411
If you can't figure it out in PiWeb, then I think you'll be stuck with a print manager software or PDF editor.  You could then use AI to write you a script that automatically stitches the cover letters to the PDF.
GhostScript would be a good option.  Here's a sample GhostScript powershell that AI wrote
For example.
CMM Exports PDF to a folder > When new files land in that folder Script stitches cover letter to front and back > Script saves PDF with cover letters to new file location.
# Configuration: Update these paths to match your environment
$watchFolder  = "C:\Paths\To\WatchFolder"
$outputFolder = "C:\Paths\To\OutputFolder"
$frontCover   = "C:\Paths\To\front_cover.pdf"
$backCover    = "C:\Paths\To\back_cover.pdf"
# Path to the Ghostscript executable (Check your installed version number)
$gsPath       = "C:\Program Files\gs\gs10.03.0\bin\gswin64c.exe"
# Set up the folder watcher
$watcher = New-Object System.IO.FileSystemWatcher
$watcher.Path = $watchFolder
$watcher.Filter = "*.pdf"
$watcher.IncludeSubdirectories = $false
$watcher.EnableRaisingEvents = $true
Write-Host "Watching $watchFolder for new PDFs..." -ForegroundColor Green
# Define what happens when a new file is detected
$action = {
    $path = $Event.SourceEventArgs.FullPath
    $name = $Event.SourceEventArgs.Name
    $outputPath = Join-Path $outputFolder $name
    Write-Host "New PDF detected: $name"
    # Wait for the file lock to release (ensures the file is fully copied before processing)
    $fileLocked = $true
    $retryCount = 0
    while ($fileLocked -and $retryCount -lt 15) {
        try {
            $stream = [System.IO.File]::Open($path, 'Open', 'Read', 'None')
            $stream.Close()
            $fileLocked = $false
        } catch {
            Start-Sleep -Seconds 1
            $retryCount++
    if (-not $fileLocked) {
        Write-Host "Stitching covers to $name..."
        # Execute Ghostscript
        & $gsPath -q -dNOPAUSE -dBATCH -sDEVICE=pdfwrite -sOutputFile="$outputPath" "$frontCover" "$path" "$backCover"
        Write-Host "Successfully saved to: $outputPath" -ForegroundColor Cyan
        # Optional: Delete the original file after processing to keep the watch folder clean
        # Remove-Item -Path $path -Force
    } else {
        Write-Host "Error: Timeout waiting for $name to unlock." -ForegroundColor Red
# Register the event to trigger the action
$job = Register-ObjectEvent $watcher "Created" -Action $action
# Keep the script running continuously
try {
    while ($true) { Start-Sleep -Seconds 1 }
} finally {
    # Clean up the background job if you stop the script (Ctrl+C)
    Unregister-Event -SourceIdentifier $job.Name
    $watcher.Dispose()
https://qualityforum.zeiss.com/topic/27087-editing-piweb-reports/#findComment-153415
