[To...] Posted July 27 Share Posted July 27 First time I’ve seen this. After performing a Ref Sphere Position, the left side does not update afterwards (manual or cnc). Right side does. Stylus qualification does update left side. Any thoughts? Link to comment https://qualityforum.zeiss.com/topic/27101-reference-sphere-info-not-updated/ Share on other sites More sharing options...
[Ma...] Posted July 27 Share Posted July 27 I was in impression, that pressing button "Ref. sphere position" will only update that right side - and because it's a master probe, that should be XYZ values zeroed, right? Link to comment https://qualityforum.zeiss.com/topic/27101-reference-sphere-info-not-updated/#findComment-153495 Share on other sites More sharing options...
[Wo...] Posted July 27 Share Posted July 27 In reference sphere management you probably have the "update stylus data" ticked off. 1 Link to comment https://qualityforum.zeiss.com/topic/27101-reference-sphere-info-not-updated/#findComment-153529 Share on other sites More sharing options...
[Za...] Posted July 27 Share Posted July 27 Please sign in to view this quote. The Update/Do not update stylus data at definition of sphere position means that when referencing the sphere’s position with the MasterProbe the Geometry of the MasterProbe will be updated based off this sphere. An instance where you may want to set this to Do not update would be if you are adding a sphere for an optical sensor. You don’t want the MasterProbe’s geometry to change based off this optical sphere instead you want the MasterProbe to tell the CMM the location of the sphere thus the optical sensor can be qualified but we want the MasterProbe to remain the same. 1 Link to comment https://qualityforum.zeiss.com/topic/27101-reference-sphere-info-not-updated/#findComment-153533 Share on other sites More sharing options...
[Wo...] Posted July 27 Share Posted July 27 The way it was explained to me was that your main reference sphere should be set to "yes" and any additional sphere should be to "no". For example I have an additional 8mm sphere to calibrate small probes and on that one I have it set to "no". Is this correct? I remember I was trying to find an answer even on the old forums and it was never really clear to me. Link to comment https://qualityforum.zeiss.com/topic/27101-reference-sphere-info-not-updated/#findComment-153537 Share on other sites More sharing options...
[Ri...] Posted July 28 Share Posted July 28 I was told, and it should still be on the forum (many years ago maybe 2015 or so), you turn off Stylus Update when you are re-qualifying a stylus. You have to reference the Master Sphere, but you do not change the Master Probe data to keep all of your styli matched as if they were all qualified together. Link to comment https://qualityforum.zeiss.com/topic/27101-reference-sphere-info-not-updated/#findComment-153548 Share on other sites More sharing options...
[To...] Posted July 28 Author Share Posted July 28 I have never changed any of this setting on any of the machines under my control. The above issue is one someone else's machine. I am looking into what that setting might be and will update the post. The 2nd part of my curiosity is does this setting have any affect on qualifying the other stylus systems? Link to comment https://qualityforum.zeiss.com/topic/27101-reference-sphere-info-not-updated/#findComment-153576 Share on other sites More sharing options...
[To...] Posted July 30 Author Share Posted July 30 Please sign in to view this quote. Please sign in to view this username. This was the issue. Now, the question is "do I need to requalify my probes"? I'm guessing the safest answer is yes. Link to comment https://qualityforum.zeiss.com/topic/27101-reference-sphere-info-not-updated/#findComment-153718 Share on other sites More sharing options...
[To...] Posted July 30 Author Share Posted July 30 Please sign in to view this quote. Please sign in to view this username. Zak, from your post it appears that if Do not update is active, the qualification of the stylus systems is based on the last known Ref Sphere Position, right?. Link to comment https://qualityforum.zeiss.com/topic/27101-reference-sphere-info-not-updated/#findComment-153720 Share on other sites More sharing options...
