Results to file, Measuring points limit 999999
Recently installed calypso 2025. They moved a few things around, and I can't seem to find the new location for the Results to file/ table file/ measuring points limit. usually set at 999999
anyone else having this issue??
below is a screenshot from our 2023 version
Seems like default value of not set - same like uncalculatable value of formula - it will fill maximum of a integer type.
In 2025, this setting has become global and can be found under the global measurement settings. It can still be configured separately for the inspection plan under "Prepare" and "File Output." The limit for measurement points can no longer be adjusted.
  • Like! 1
 is correct. The global settings option has been a nice addition; it removes the risk of forgetting to turn it on and losing measurement points.
Also, for older systems, for an infinite number of measurement points, you can enter "0" for the measuring point limit
