Check existence and location of table files at end of run
Is there a way in PCM to find out at the end of a run
  • whether a characteristic table file was generated and exported (i.e. if the table file option was activated in the start window AND if the custom path setting was set and activated)
  • where (custom path and file name) it was exported to.
I think this would need a few "undocumented" commands. Does anyone happen to know some? 🙂
Edited
Hello Norbert,
all generated files are logged in the protocols.log file located in the actuals directory (directoryPath("actuals")):
baseSystem().machine.inspection.settings.protocollog
settingGet("protocollog")
remark: baseSystem().machine.inspection.settings.blabla is the "same" as settingGet("blabla")
If the table file option is activated in the start window:
baseSystem().machine.inspection.settings.resultToTableFileDialog
settingGet("resultToTableFileDialog")
settingGet("resultToTableFile") shows if table files are activated
You can check custom path settings with
baseSystem().machine.inspection.settings.protocolSettings.outputFileDefinition
settingGet("protocolSettings").outputFileDefinition
especially (returns nil if not)
baseSystem().machine.inspection.settings.protocolSettings.outputFileDefinition.tableFileHdr
baseSystem().machine.inspection.protocol.protocolSettings.outputFileDefinition.tableFileChr
baseSystem().machine.inspection.protocol.protocolSettings.outputFileDefinition.tableFileFet
  • Like! 1
  • Thank you! 1
Edit: Missing files are labeled with MISSING in the protocols.log file:
C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\results\somtehing_2026_07_28_pwr.pdf     MISSING
By the way: Why can't I edit my posts anymore?
  • Like! 1
  • Thank you! 1
Insane! :classic_blink::classic_laugh: Thanks a lot!
I didn't expect it to be that easy. Never payed attention to that log file before.
Does the log grow or does it always mirror the state of the last run? Because if it doesn't grow and missing files are marked, I probably won't need all the other check functions. 👍
The best time to run my code (from an external PCM file) is something I have yet to figure out. I will probably just read the protocol name from that log and hope it wil already be updated at that time. But thinking about it, the best way to do it would be to retrieve the actual string written by Calypso to the log. That would also avoid possible errors if the configuration is changed in the future.
Things from \config\env\values for example. How does one figure out all those queries in the first place? I'm clearly mssing something here although I know the basics.
 The content of \config\env\values should be displayed using
baseSystem().machine.environment.OMConfiguration.getMastersEnvMemory
  or
baseSystem().machine.environment.OMConfiguration.classPool.Memory.env
For Instance the default actuals path:
baseSystem().machine.environment.OMConfiguration.getMastersEnvMemory.defaultPathForActuals
It is just possible to access the underlying smalltalk layer using pcm. Actually, by Zeiss this kind of pcm code isn't intended to be used. So it is not documented and not easy to to figure it out.
  • 4 weeks later...
Unfortunately I ran into a problem:
If I use the command that queries tableFileChr in a new inspection plan where no custom path settings for the table file have ever been made, I get a PCM error (attribute not allowed). I guess it's because the Dictionary "outputFileDefinition" is either empty or doesn't contain an entry for tableFileChar. Is there a way around this or can I query this condition somehow?
Maybe check first if the Dictionary is not empty and a key tableFileChar exists. Actually the latter should be enough.
outFileDef=baseSystem().machine.inspection.protocol.protocolSettings.outputFileDefinition
if ((not(outFileDef.isEmpty)) and (inStr(outFileDef.keys.asString,"tableFiletableFileChar")>0))
endif
  • Like! 3
