[Ra...] Posted July 29 Share Posted July 29 For those that have "newer" versions of Calypso. Do the toggle buttons on top right of basic form plot go away at some point and you are only left with the first one (PiWeb)? I have v6.6, and was helping a colleague with v7.4 (or later) and he alleges his form plotting option is only the PiWeb toggle button. Thanks. Link to comment https://qualityforum.zeiss.com/topic/27128-characteristic-form-plots-later-calypso-versions/ Share on other sites More sharing options...
[Ma...] Posted July 29 Share Posted July 29 I don't have them anymore, but i am not totaly sure. You can still enable old protocols, so they may be visible once you enable it in program. 1 Link to comment https://qualityforum.zeiss.com/topic/27128-characteristic-form-plots-later-calypso-versions/#findComment-153654 Share on other sites More sharing options...
[Th...] Posted July 29 Share Posted July 29 Yes, the compatibility setting that re-enables the old plots also shows or hides those buttons. Link to comment https://qualityforum.zeiss.com/topic/27128-characteristic-form-plots-later-calypso-versions/#findComment-153656 Share on other sites More sharing options...
[Ja...] Posted July 29 Share Posted July 29 How do you re-enable them? Link to comment https://qualityforum.zeiss.com/topic/27128-characteristic-form-plots-later-calypso-versions/#findComment-153660 Share on other sites More sharing options...
[Th...] Posted July 29 Share Posted July 29 It's under Resources > Compatibility settings > For this measurement plan Fourth from the bottom is "Show discontinued report templates". Enable that. Also verify that your colleague has the "ZEISS Basic Reporting" application installed (or "ZEISS Basic Reporting64" if they're using Calypso 2024 or newer). It's not part of the standard install anymore so it might not be on the PC. 1 1 Link to comment https://qualityforum.zeiss.com/topic/27128-characteristic-form-plots-later-calypso-versions/#findComment-153662 Share on other sites More sharing options...
[Ja...] Posted July 31 Share Posted July 31 Thanks. All of our stations are always running the latest and greatest. Doesn't look like the Basic Reporting64 is installed. Link to comment https://qualityforum.zeiss.com/topic/27128-characteristic-form-plots-later-calypso-versions/#findComment-153766 Share on other sites More sharing options...
[Th...] Posted July 31 Share Posted July 31 If you still have the installation pack, it's stored in the tools folder. 1 Link to comment https://qualityforum.zeiss.com/topic/27128-characteristic-form-plots-later-calypso-versions/#findComment-153776 Share on other sites More sharing options...
