[El...] Posted July 30 Share Posted July 30 Hi, what's the strategy for measuring the "CZ" position tolerance for the 5 cylinders indicated, using the Calypso 2020 release 7.0.12? Also, how is the deviation represented in piweb format? Thanks in advance. Link to comment Share on other sites More sharing options...
[Ma...] Posted July 30 Share Posted July 30 I think it will be perpendicularity to A using pattern 1 Link to comment Share on other sites More sharing options...
[ni...] Posted July 31 Share Posted July 31 There is a CZ, so do a localisation / best fit, select the 5 cylinders, and the plan A as datum, and check translation and rotation alowed 1 Link to comment Share on other sites More sharing options...
[El...] Posted July 31 Author Share Posted July 31 Okay. This is what I did. I'm attaching the settings (is it correct?) and the results, but I'm not clear about the report results. Thanks Link to comment Share on other sites More sharing options...
[ni...] Posted 1 hour ago Share Posted 1 hour ago Hi, back to work after holidays :) to do a best fit, you have to check the three box (Rotation and translation Z & X) (like you did it's the equivalent of 5 separate true position) Link to comment Share on other sites More sharing options...
