[Jo...] Posted July 30 Share Posted July 30 I have a program that is giving me trouble trying to use multiple strategies. Normally when I add a second strategy and select that strategy from the Run screen, it executes as expected. In this particular program no matter what strategy I select from the run screen the "***" strategy always runs for all features. Can other things determine which strategy gets used besides the selection at the run screen? Do other settings force the default strategy? I am a little stumped! Link to comment https://qualityforum.zeiss.com/topic/27142-multiple-strategies-for-one-feature-not-working-sometimes/ Share on other sites More sharing options...
[Ow...] Posted July 30 Share Posted July 30 Do you mean selecting features or characteristics with different strategies from the run screen? If so, my guess is one feature has a relation to the other, like one is needed for the alignment or condition of the other? Link to comment https://qualityforum.zeiss.com/topic/27142-multiple-strategies-for-one-feature-not-working-sometimes/#findComment-153742 Share on other sites More sharing options...
[Jo...] Posted July 31 Author Share Posted July 31 That was what i am thinking too... But none of my strategies are dynamic or use PCM. Only manually selected from the run screen. I may have somehow "corrupted" my program. It is working fine in every other scenario I can contrive to test it except this well lived program. Link to comment https://qualityforum.zeiss.com/topic/27142-multiple-strategies-for-one-feature-not-working-sometimes/#findComment-153754 Share on other sites More sharing options...
[Ow...] Posted July 31 Share Posted July 31 (edited) In the start menu under CMM order or run, are you running from features or characteristics? I've found that running from Characteristics will sometime create unexpected dependencies, maybe because I've only run from the characteristics side maybe 10 times in 20 years(?). Depending on what version you're running, right click on the feature you are selecting to run and choose check use of selected features and see if it shows any unknown dependency - or - choose to execute the feature and see if it only runs or the other others you are seeing it do when chosen from the start menu. Just thinking out loud, do you have any mini-plans set-up in the program? Edited July 31 Link to comment https://qualityforum.zeiss.com/topic/27142-multiple-strategies-for-one-feature-not-working-sometimes/#findComment-153760 Share on other sites More sharing options...
