[Jo...] Posted August 1 Share Posted August 1 Hello, I have a CAD file with datum point in. These datum points are named in the CAD program and the name is in the retained in the exported STEP file. In the STEP file this is a Cartesian point. See line from the file. Please sign in to view this quote. I would like to import this point into Calypso and keep the point name in Calypso. It should become a space point. But when I do an import of the Step file in Calypso, the points are showing up as Point1, Point2, Point3, .... and so on. The original point name is not available in Calypso. What are the possible method to import these point with name in Calypso? Implement in the step importer similar as in the Zeiss inspect; Create a import script for these points; Other CAD export format; Other method. Link to comment https://qualityforum.zeiss.com/topic/27156-import-cad-file-step-format-retain-point-names-from-step-file/ Share on other sites More sharing options...
[Ri...] Posted August 3 Share Posted August 3 Sounds like PMI. Your step file has to be a specific version for PMI and if it is that version, once the file is opened you get an extra Tab next to Features Tab for PMI. STEP AP242 (ISO 10303-242) Link to comment https://qualityforum.zeiss.com/topic/27156-import-cad-file-step-format-retain-point-names-from-step-file/#findComment-153806 Share on other sites More sharing options...
[Ma...] Posted August 3 Share Posted August 3 Hi, like Please sign in to view this username. said, this could only be done with PMI, we do not convert "Entity Names" in the CAD Conversion. That would be a whole you requirement for CALYPSO. Best Regards Marcel Link to comment https://qualityforum.zeiss.com/topic/27156-import-cad-file-step-format-retain-point-names-from-step-file/#findComment-153810 Share on other sites More sharing options...
[Jo...] Posted August 3 Author Share Posted August 3 Hello, And the PMI module is an additional license? And maybe I have to change also the workflow at our CAD side. Johnny Link to comment https://qualityforum.zeiss.com/topic/27156-import-cad-file-step-format-retain-point-names-from-step-file/#findComment-153820 Share on other sites More sharing options...
[Ma...] Posted August 4 Share Posted August 4 Hi Johnny, PMI is included within CALYPSO, it doesn't require an additional license. But please see the Release Info for CAD/PMI compatibility: Best Regards Marcel Link to comment https://qualityforum.zeiss.com/topic/27156-import-cad-file-step-format-retain-point-names-from-step-file/#findComment-153862 Share on other sites More sharing options...
[Jö...] Posted August 4 Share Posted August 4 Please sign in to view this quote. wusste garnicht das man man für PMI nicht bezahlen muss. Meines Wissens, muss man für PMI bezahlen. Link to comment https://qualityforum.zeiss.com/topic/27156-import-cad-file-step-format-retain-point-names-from-step-file/#findComment-153868 Share on other sites More sharing options...
[Ma...] Posted August 4 Share Posted August 4 Ich klär es mal eben mit der Anwendungstechnik, nicht das meine Info falsch ist 🙂 Link to comment https://qualityforum.zeiss.com/topic/27156-import-cad-file-step-format-retain-point-names-from-step-file/#findComment-153870 Share on other sites More sharing options...
[Ma...] Posted August 5 Share Posted August 5 Nach Rücksprache mit dem zuständigen Kollegen für PMI aus der Anwendungstechnik ist PMI definitiv kostenlos, lediglich für die native CAD Schnittstelle (außer .Sab/.Sat) muss bezahlt werden: 1 Link to comment https://qualityforum.zeiss.com/topic/27156-import-cad-file-step-format-retain-point-names-from-step-file/#findComment-153892 Share on other sites More sharing options...
[Ri...] Posted August 5 Share Posted August 5 As a side note, using Calypso v2022, if you save the PMI enabled CAD model from within Calypso it appears to lose the PMI information. Link to comment https://qualityforum.zeiss.com/topic/27156-import-cad-file-step-format-retain-point-names-from-step-file/#findComment-153912 Share on other sites More sharing options...
