[Jo...] Posted 5 hours ago Share Posted 5 hours ago Hello, I have a CAD file with datum point in. These datum points are named in the CAD program and the name is in the retained in the exported STEP file. In the STEP file this is a Cartesian point. See line from the file. Please sign in to view this quote. I would like to import this point into Calypso and keep the point name in Calypso. It should become a space point. But when I do an import of the Step file in Calypso, the points are showing up as Point1, Point2, Point3, .... and so on. The original point name is not available in Calypso. What are the possible method to import these point with name in Calypso? Implement in the step importer similar as in the Zeiss inspect; Create a import script for these points; Other CAD export format; Other method. Link to comment Share on other sites More sharing options...
