[Lu...] Posted August 3 Share Posted August 3 (edited) Hi guys, I'm working with a brand-new Contura 700/1000/600 machine. We purchased it with the new RDS VAST XXT TL3 shorter head. Does anyone know the accuracy of the CAA function? I already have quite a few angular positions configured with different styli. I was thinking about using the CAA function to reduce calibration time, but I read somewhere that the accuracy with CAA isn't particularly good. I've already asked Zeiss France, but no one seems to know the actual accuracy. Some people told me it's around 0.1–0.2 mm, while others mentioned 0.05 mm. Does anyone have any information or experience with the RC-CAA function? luis Edited August 3 Link to comment https://qualityforum.zeiss.com/topic/27162-rds-vast-xxt-rc-caa-precision-on-the-new-shorted-head-tl3/ Share on other sites More sharing options...
[Ri...] Posted August 3 Share Posted August 3 I am using the original RDS CAA sensor in CAA mode, its accuracy is outstanding. I have compared it to the VAST XTR for my own sanity and haven't found anything that would trigger an issue with accuracy. I don't have actual accuracy numbers. I have used features with the XTR for Diameter and location then used the same features with the RDS with no loss of accuracy up to the 5th decimal in Inch's. Worst case I noticed was a compound angle feature and my true position was .00011" (RDS) different in the result. Considering two axis and two rotations, that's quite accurate in my eyes. Link to comment https://qualityforum.zeiss.com/topic/27162-rds-vast-xxt-rc-caa-precision-on-the-new-shorted-head-tl3/#findComment-153834 Share on other sites More sharing options...
[Lu...] Posted August 4 Author Share Posted August 4 Thanks for your help, Please sign in to view this username. Do you know if I need to create another stylus profile with a different name to enable CAA, or can I use a hybrid setup? In other words, can I use CAA while keeping the standard calibration for a passive stylus? Link to comment https://qualityforum.zeiss.com/topic/27162-rds-vast-xxt-rc-caa-precision-on-the-new-shorted-head-tl3/#findComment-153858 Share on other sites More sharing options...
[Jo...] Posted August 4 Share Posted August 4 Please sign in to view this quote. Sort of! It has to be a separate stylus system. You will have to manually reassign which probe is in your probe holder, the regular or the CAA probe, to switch between the two. But there is no problem having both set up and qualified. Link to comment https://qualityforum.zeiss.com/topic/27162-rds-vast-xxt-rc-caa-precision-on-the-new-shorted-head-tl3/#findComment-153884 Share on other sites More sharing options...
[Vo...] Posted August 5 Share Posted August 5 Hallo, das mit dem RDS-CAA ist so eine Sache. Der Hersteller macht darüber keine Angaben wie hoch die Grenzwerte dafür sind. Es bleibt dem Anwender überlassen, abzuschätzen wie "genau" man damit ist. Es gibt Vorgaben aus Normen, z. Bsp. die Mehfachtaster-Antastabweichung mit der man zum Beispiel seine Grenzwerte ermitteln kann, sowohl beim empirischen einmessen als auch beim abgeleiteten einmessen. Ich habe festgestellt, dass die Genauigkeit sehr stark von Faktoren wie, Umgebungsbedingungen abhängig ist. Es bleibt dir nichts anderes übrig, deine Grenzwerte für diese Messmaschine selber zu definieren. MfG Volker Link to comment https://qualityforum.zeiss.com/topic/27162-rds-vast-xxt-rc-caa-precision-on-the-new-shorted-head-tl3/#findComment-153898 Share on other sites More sharing options...
[Er...] Posted August 5 Share Posted August 5 (edited) Here is what you typically can expect on a Contura equied with the sensor you specifed. Zeiss limit values: PLTI 20µm PLTE 10µm Actual values: PLTI 12µm PLTE 6µm Edited August 5 1 Link to comment https://qualityforum.zeiss.com/topic/27162-rds-vast-xxt-rc-caa-precision-on-the-new-shorted-head-tl3/#findComment-153906 Share on other sites More sharing options...
[Ri...] Posted August 5 Share Posted August 5 Please sign in to view this quote. As far as I know, and I have never tried it, you will need a separate profile name. I don't know how that would work when using Chip ID's, which I use that all the time. Link to comment https://qualityforum.zeiss.com/topic/27162-rds-vast-xxt-rc-caa-precision-on-the-new-shorted-head-tl3/#findComment-153910 Share on other sites More sharing options...
[Lu...] Posted August 5 Author Share Posted August 5 thank you Please sign in to view this username. . I have anoter question regarding calibration values i have a probe D6L100 with carbon fiber body and ia had a small colision with the probe. before the colision i had sigma values on calibrabrion arround 0.0002 and after colision arround 0.0008 to 0.0014 depending on angular position. what sigma values should i accept regarding your experience. this is a long stylus with 100mm of length. Link to comment https://qualityforum.zeiss.com/topic/27162-rds-vast-xxt-rc-caa-precision-on-the-new-shorted-head-tl3/#findComment-153924 Share on other sites More sharing options...
[Jo...] Posted August 5 Share Posted August 5 Please sign in to view this quote. You can assign the same chipid to multiple probes Link to comment https://qualityforum.zeiss.com/topic/27162-rds-vast-xxt-rc-caa-precision-on-the-new-shorted-head-tl3/#findComment-153926 Share on other sites More sharing options...
[Ri...] Posted August 5 Share Posted August 5 Please sign in to view this quote. I meant to use a single probe as CAA and a List. Can that be done? Link to comment https://qualityforum.zeiss.com/topic/27162-rds-vast-xxt-rc-caa-precision-on-the-new-shorted-head-tl3/#findComment-153940 Share on other sites More sharing options...
[Lu...] Posted August 6 Author Share Posted August 6 Please sign in to view this quote. Please sign in to view this username. can you explain us? Link to comment https://qualityforum.zeiss.com/topic/27162-rds-vast-xxt-rc-caa-precision-on-the-new-shorted-head-tl3/#findComment-153980 Share on other sites More sharing options...
[Ri...] Posted August 6 Share Posted August 6 Please sign in to view this quote. I would be suspicious of the carbon shaft having a fracture or possibly the glue at any joint of metal or stylus to the shaft. Personally, I would not accept the results of 0.0008-0.0014. 2 Link to comment https://qualityforum.zeiss.com/topic/27162-rds-vast-xxt-rc-caa-precision-on-the-new-shorted-head-tl3/#findComment-153984 Share on other sites More sharing options...
[Lu...] Posted August 6 Author Share Posted August 6 Thank you Please sign in to view this username. Link to comment https://qualityforum.zeiss.com/topic/27162-rds-vast-xxt-rc-caa-precision-on-the-new-shorted-head-tl3/#findComment-154002 Share on other sites More sharing options...
[Jo...] Posted August 6 Share Posted August 6 You can set up and qualify a probe as a CAA probe. Then set up and qualify the same physical probe as a list-probe. Calypso will let you assign as many probes as you like to an adapter plate/chipID. The caveat is that you cannot have both probes installed into the probe rack at the same time (since they would need to use the same holder). To make this work we have programs that are either "only CAA", or "no CAA" for that probe and we reassign the correct probe to the holder before running it. 2 Link to comment https://qualityforum.zeiss.com/topic/27162-rds-vast-xxt-rc-caa-precision-on-the-new-shorted-head-tl3/#findComment-154030 Share on other sites More sharing options...
[Ra...] Posted August 6 Share Posted August 6 From the great @Tom Oakes: You can create what I have designated as "Ghost Holders". Let's say you have one physical 3 position XXT holder. I add a new stylus system holder. Then, define the location of the new holder using the original #1 holder. I put my standard configured probe in the #1 holder and my RDS-CAA configured probe in the #2 holder. When I want to switch from standard to CAA, it stores the standard version and then picks it back up as the CAA version. Obviously, this can cause some confusion so everyone has to be on the same page. 2 Link to comment https://qualityforum.zeiss.com/topic/27162-rds-vast-xxt-rc-caa-precision-on-the-new-shorted-head-tl3/#findComment-154034 Share on other sites More sharing options...
[Jo...] Posted August 7 Share Posted August 7 Yet another lifechanging tip from Please sign in to view this username. ! That is fantastic! 1 Link to comment https://qualityforum.zeiss.com/topic/27162-rds-vast-xxt-rc-caa-precision-on-the-new-shorted-head-tl3/#findComment-154078 Share on other sites More sharing options...
[Lu...] Posted August 11 Author Share Posted August 11 Thanks guys for the comments but regarding the precision of the CAA version anyone have idea what kind of precision i can have with the CAA version using a angle that is not one of the 12 calibrated angles regarding the standard method that angle is calibrated using the function calibrate passive stylus? Link to comment https://qualityforum.zeiss.com/topic/27162-rds-vast-xxt-rc-caa-precision-on-the-new-shorted-head-tl3/#findComment-154144 Share on other sites More sharing options...
