Error atosmmt-001 Connection to Database is Broken
I would start with making sure you are on the most up to date version of the Image aquisition drive and hardware service for the version you are using.
I would then make sure everything connects correctly in the Measuring Device Manager.
If the issue persists please pull a GOMSIC and contact your local support.
https://portal.zeiss.com/knowledge-base?id=3047314
