[Kl...] Posted Tuesday at 04:23 PM Share Posted Tuesday at 04:23 PM When i try to take a shot in photogrammetry i get the same error, I'm able to program it offline and run the program when online. However if i try to manually take a shot it refuses to do so and I'm at a loss Link to comment Share on other sites More sharing options...
[Mi...] Posted 18 hours ago Share Posted 18 hours ago I would start with making sure you are on the most up to date version of the Image aquisition drive and hardware service for the version you are using. I would then make sure everything connects correctly in the Measuring Device Manager. If the issue persists please pull a GOMSIC and contact your local support. https://portal.zeiss.com/knowledge-base?id=3047314 Link to comment Share on other sites More sharing options...
[Kl...] Posted 17 hours ago Author Share Posted 17 hours ago Everything seems to be up to date and connected correctly, I will have my boss reach out for local support. Thank you Link to comment Share on other sites More sharing options...
