[Ni...] Posted August 5 Share Posted August 5 Hi everyone, First of all: the text has been translated - sorry for any mistakes... On the rotary table, I have a part with 12 x 30° faces around its circumference. The plane rotation is one of these planes. After manual alignment, the table rotates to the probed surface, which is parallel to the X-axis. However, when I start the program using the pre-calibrated start system, the table rotates to 0°, and the surface is then not parallel to the X-axis. What do I need to do to ensure that the table aligns the surface parallel to the X-axis even when using the pre-calibrated start system? Thanks in advance! Best regards Link to comment https://qualityforum.zeiss.com/topic/27182-align-rt-to-surface/ Share on other sites More sharing options...
[Ra...] Posted August 6 Share Posted August 6 Do you have PCM? If so: getRTOffset() Rotary Table Offset value getRTPosition() Latest position of Rotary table getRTPositionCMM() Latest position of Rotary table in machine coordinate-system rtPositionOffset() Define offset for RT (angle in radians) rotateAbsolute() rotateReference() goHome(vector) Rotates RT to specified vector rtIsActive() Boolean value, Is rotary table active? true/false rotateWithDriveFree() Boolean value, Is rotary table active? true/false Link to comment https://qualityforum.zeiss.com/topic/27182-align-rt-to-surface/#findComment-154008 Share on other sites More sharing options...
[Ch...] Posted August 6 Share Posted August 6 there is also an option to 'align to feature' which should do it for you. Link to comment https://qualityforum.zeiss.com/topic/27182-align-rt-to-surface/#findComment-154022 Share on other sites More sharing options...
[Ed...] Posted August 7 Share Posted August 7 I usually select Normal from Feature and Base Alignment Axis. On the Normal from feature, I use a copy of the Planar Rotation from my base alignment. 1 Link to comment https://qualityforum.zeiss.com/topic/27182-align-rt-to-surface/#findComment-154092 Share on other sites More sharing options...
[Ni...] Posted August 12 Author Share Posted August 12 Thanks everyone! I think the Normal from Feature with a copy will be good for us. Link to comment https://qualityforum.zeiss.com/topic/27182-align-rt-to-surface/#findComment-154190 Share on other sites More sharing options...
