Align RT to Surface
Hi everyone,
First of all: the text has been translated - sorry for any mistakes...
On the rotary table, I have a part with 12 x 30° faces around its circumference. The plane rotation is one of these planes.
After manual alignment, the table rotates to the probed surface, which is parallel to the X-axis.
However, when I start the program using the pre-calibrated start system, the table rotates to 0°, and the surface is then not parallel to the X-axis.
What do I need to do to ensure that the table aligns the surface parallel to the X-axis even when using the pre-calibrated start system?
Thanks in advance!
Best regards
