[Ke...] Posted August 5 Share Posted August 5 How would i take my actual scan data and show low/ high spots? I don't have CAD but is there a way to show flatness in a form of where the part has deviation? I understand the Flatness call out but being able to show something along the lines of deviation labels? Link to comment Share on other sites More sharing options...
[Jo...] Posted August 6 Share Posted August 6 (edited) You could compare it to the mesh of a reference sample. You can load that as CAD. for flatness this is possible like so: build an alignment build a plane check the plane for flatness go to properties and activate "show colour ..." put some deviation labels on if you like Also works for other geometric elemnts Edited August 6 Link to comment Share on other sites More sharing options...
[Ke...] Posted August 6 Author Share Posted August 6 When i load it as a CAD model there is ZERO deviation. How would i show Actual mesh data having low and high spots without using CAD model? Link to comment Share on other sites More sharing options...
[Jo...] Posted August 6 Share Posted August 6 When you load the same mesh as CAD it should show no deviations. Working as intended. Thats why i mentioned a reference sample or master part. To my knowledge, you can`t compare freeform without a CAD. The CAD is the information for the comparision. Link to comment Share on other sites More sharing options...
[Ma...] Posted 2 hours ago Share Posted 2 hours ago 1. Create a plane. 2. Create a flatness Double-click the result. A window will open on the right side. Display. Enable color display. Link to comment Share on other sites More sharing options...
