BREAKOUT DIAMETER
I am trying to measure a break out diameter for size.   basically it is a ring type part that has a center bore, a plane and web.  The web has radius that is less than 60degrees of an arc that is intersected with the plane.  Where the plane and radius meets is the diameter I need.  The radius is part of a line profile (several around the part) measured with a curve.  So i have the curve points.  I recalled those points into individual diameters.   If I was just measuring the radius, it would just constrain the size to get location and constrain the position to get the size... in this case I need both at same time. I tried using a theoretical diameter and formulas to input the location and size of the recalled points and then intersect with the plane.  When i do this I get a diameter that does not make any sense. Any ideas on why?
https://qualityforum.zeiss.com/topic/27186-breakout-diameter/
Joe is correct, this isn't a measurement strategy issue, its a math issue.  You can't get an accurate diameter on short radii.  There's several good white papers online that describe how much uncertainty you accumulate as you make your radius smaller.  My analogy is this is like trying to calculate the circumference of the Earth by going out and measuring your parking lot.
Would it be acceptable to use profile instead?  A profile would ensure your radius is in the correct location and is the correct size.
https://qualityforum.zeiss.com/topic/27186-breakout-diameter/#findComment-154136
i went down a rabbit hole and I really do not know why (kind of do with all the feed back) but this is what I found
I did a test 3 different ways... 1) 3d Curve (original scan.. .Zeiss told me to do it this way on this program a long, long time ago) 2) a 2D curve and 3) finally just a diameter
What i found out in a 3D curve when recalling into a diameter, i do not have to constrain pos for radius and radius for pos... but with a 2d curve and diameter.. I do....
All three checks now read relatively the same for pos and size.   When plotting to curve points in Cad software, I get within .001 of what the machine was saying.  I then did a trace on the part with a contour device and got within .001 also...
  • Like! 1
https://qualityforum.zeiss.com/topic/27186-breakout-diameter/#findComment-154254
