Unqualified probe
Hello PCM Masters,
Is there any property of getProbe or any other way to check probe's qualification status?
It is green when qualified (qual. date and time are updated and all other data)
It is red when is was NOT qualified (qual. date and time stay from the previous qualification and all other data)
Edited
https://qualityforum.zeiss.com/topic/27188-unqualified-probe/
getProbe().calibration  // active stylus calibrated
getProbe("STYLUS","STYLUS SYSTEM").calibration  // for an existing specified stylus
Further commands:
https://qualityforum.zeiss.com/topic/17112-getprobe-characteristics/?do=findComment&comment=95734
or inside the pcm manual:
C:\Program Files (x86)\Zeiss\CALYPSO X.X\userinfo\manuals\en\Calypso_02_PCM.pdf
  • Like! 1
https://qualityforum.zeiss.com/topic/27188-unqualified-probe/#findComment-153968
 wow... I tried so many combination and this obvious one I missed.. well.. thank you
 unfortunately it won't prevent the scenario where your probe's sigma is beyond 0.01 (default setting in "Limit values for CNC qualification" unless you've changed it). In that case your data won't update and your PCM will compute it as "successful" qualification
  • Like! 1
https://qualityforum.zeiss.com/topic/27188-unqualified-probe/#findComment-154122
