[Ma...] Posted 7 hours ago Share Posted 7 hours ago (edited) Hello PCM Masters, Is there any property of getProbe or any other way to check probe's qualification status? It is green when qualified (qual. date and time are updated and all other data) It is red when is was NOT qualified (qual. date and time stay from the previous qualification and all other data) Edited 7 hours ago attachment Link to comment Share on other sites More sharing options...
[Ma...] Posted 6 hours ago Author Share Posted 6 hours ago Same with Probing System Qualification - cannot access the state of characteristic. Link to comment Share on other sites More sharing options...
[na...] Posted 6 hours ago Share Posted 6 hours ago Please sign in to view this quote. I'm not 100%, but close -> getProbe("5_-X","star_3").calibration it should return true or false. Link to comment Share on other sites More sharing options...
[Ma...] Posted 6 hours ago Author Share Posted 6 hours ago Please sign in to view this username. I already tried that and it does not show the status I need 😕 Link to comment Share on other sites More sharing options...
[Mi...] Posted 6 hours ago Share Posted 6 hours ago getProbe().calibration // active stylus calibrated getProbe("STYLUS","STYLUS SYSTEM").calibration // for an existing specified stylus Further commands: https://qualityforum.zeiss.com/topic/17112-getprobe-characteristics/?do=findComment&comment=95734 or inside the pcm manual: C:\Program Files (x86)\Zeiss\CALYPSO X.X\userinfo\manuals\en\Calypso_02_PCM.pdf 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted 6 hours ago Author Share Posted 6 hours ago Please sign in to view this username. Same as above. I bet it shows if the probe was EVER calibrated before (have date of calibration) but not its actual status. Link to comment Share on other sites More sharing options...
[na...] Posted 6 hours ago Share Posted 6 hours ago Please sign in to view this quote. check naming and quotes -> getProbe("1_-Z","10").calibration Link to comment Share on other sites More sharing options...
[Ma...] Posted 6 hours ago Author Share Posted 6 hours ago Please sign in to view this username. Not the case, same results. I created new stylus system, did not qualify it and it says "false" to calibration property - as I thought. Link to comment Share on other sites More sharing options...
[Mi...] Posted 1 hour ago Share Posted 1 hour ago You have to use getNominal instead of getActual: getNominal("MyProbe").toleranceState 1 Link to comment Share on other sites More sharing options...
