[Cr...] Posted August 12 Share Posted August 12 We just got the ATOS Q 8M with ScanPort, and I am trying to calibrate the MV50 lens. I can get Position 1 to pass. My question is: how do I move the ScanPort for the next position 2 without exiting the calibration window?" Link to comment https://qualityforum.zeiss.com/topic/27220-atos-q-calibration/ Share on other sites More sharing options...
[Ri...] Posted August 12 Share Posted August 12 The ScanPort has its own app for calibration. It will handle it for you. Though I'm not certain if the normal ScanPort app handles the MV50 by default. Link to comment https://qualityforum.zeiss.com/topic/27220-atos-q-calibration/#findComment-154228 Share on other sites More sharing options...
[Jo...] Posted August 13 Share Posted August 13 (edited) MV50 will probably be problematic due to vibrations and movement checks. You can use the scanport app --> full calibration. Or use a tritop. Edited August 13 Link to comment https://qualityforum.zeiss.com/topic/27220-atos-q-calibration/#findComment-154236 Share on other sites More sharing options...
[Cr...] Posted August 21 Author Share Posted August 21 Jochen, thank you for the suggestion. I am using MV270 lenses, Calibration worked until I had to tilt 45 deg, and I can't figure out why it's saying 'WRONG TILT DIRECTION' and how to proceed. I attached a image with the calibration panel set-up. Link to comment https://qualityforum.zeiss.com/topic/27220-atos-q-calibration/#findComment-154584 Share on other sites More sharing options...
[Ri...] Posted August 22 Share Posted August 22 Please sign in to view this username. I believe you have the grid plate rotated 180°. Link to comment https://qualityforum.zeiss.com/topic/27220-atos-q-calibration/#findComment-154588 Share on other sites More sharing options...
[Ma...] Posted August 22 Share Posted August 22 Please sign in to view this username. i think he is allright. That 4 points in the middle is oriented correctly ( at least from lower camera images ) and accordingly to picture hints. What i don't understand is why there are 4 camera screens displaying different things. Link to comment https://qualityforum.zeiss.com/topic/27220-atos-q-calibration/#findComment-154590 Share on other sites More sharing options...
[Jo...] Posted August 24 Share Posted August 24 Looks about right on the picture. Is that the plate for 270? Looks the same size as our 350 plate. for the 350 i had to remove the rotation table to make it work on the scanport. In general: You have two angled positions where you have to move the whole stand facing opposing directions. Inbetween you have two rotate the calibration plate. Link to comment https://qualityforum.zeiss.com/topic/27220-atos-q-calibration/#findComment-154592 Share on other sites More sharing options...
