[Ch...] Posted August 17 Share Posted August 17 I created a new "machine" in planner, I then created all of the probes in Stylus system creator. When I imported the Master Probe into planner, I get this: As you can see the probe does not align with the "system" probe. Is there any way to get them to align? With all the other probes I just manipulate the geo until they are lined up in all 3 axis. Link to comment https://qualityforum.zeiss.com/topic/27246-master-probe-mis-aligment/ Share on other sites More sharing options...
[Ke...] Posted August 17 Share Posted August 17 I would suggest trying this guide and see if it corrects the issue Link to comment https://qualityforum.zeiss.com/topic/27246-master-probe-mis-aligment/#findComment-154384 Share on other sites More sharing options...
[Ch...] Posted August 18 Share Posted August 18 You may also want to try performing a manual alignment "in simulation" to make sure everything base alignment related is matching. Link to comment https://qualityforum.zeiss.com/topic/27246-master-probe-mis-aligment/#findComment-154438 Share on other sites More sharing options...
