[To...] Posted 2 hours ago Share Posted 2 hours ago The SSD on my Zeiss computer has crashed. I need to install windows10 IoT ENt2016 LTSB High End on a new SSD. I'm very comfortable with other versions of Windows installs. Has anyone ever done this ? Can anyone give me specific info on which version I need to download? I have tested the old SSD in another computer and cannot access files. Link to comment Share on other sites More sharing options...
[DW...] Posted 2 hours ago Share Posted 2 hours ago (edited) Please sign in to view this quote. Please sign in to view this username. Can you give a little more description about not being able to access files? Can you see it detected in BIOS? Does the SSD appear in Disk Management but shows RAW or Unallocated? Or it it not detectable at all? Edited 2 hours ago Link to comment Share on other sites More sharing options...
[Ma...] Posted 1 hour ago Share Posted 1 hour ago SSDs mostly die for sure. I think dead controller. I had no luck with "shorted cap" on any SSD Link to comment Share on other sites More sharing options...
[Ab...] Posted 1 hour ago Share Posted 1 hour ago Hello I would suggest contacting windows, to see if you can install a different version of windows on your SSD or same version, they can also provide you with the product key/license for your windows to install if you do not have that already . Link to comment Share on other sites More sharing options...
[Th...] Posted 1 hour ago Share Posted 1 hour ago Do you actually need LTSB 2016 specifically? I don't think Microsoft is offering any of the Win10 images officially anymore, and LTSB 2016 end of support is in a couple of months. If you just need an OS so you can get a CMM running, just throw 11 Pro on it. Our IT department did that for 3 of our shop machines and it's been fine. 1 Link to comment Share on other sites More sharing options...
[Ab...] Posted 1 hour ago Share Posted 1 hour ago i would also suggest, if you are upgrading the windows version, to make sure it is compatible with the version of calypso you are using. Link to comment Share on other sites More sharing options...
[Ab...] Posted 1 hour ago Share Posted 1 hour ago We have a Knowledge base article that gives you overview of what windows version are compatible with what version of calypso https://portal.zeiss.com/knowledge-base?id=815374 Link to comment Share on other sites More sharing options...
[To...] Posted 8 minutes ago Author Share Posted 8 minutes ago (edited) Please sign in to view this quote. Please sign in to view this username. Can't get into BIOS with SSD connected. Cannot view any files when SSD is installed as a secondary drive in a working computer. Disk management does not see it either. Edited 4 minutes ago Link to comment Share on other sites More sharing options...
[To...] Posted 4 minutes ago Author Share Posted 4 minutes ago (edited) Please sign in to view this quote. Please sign in to view this username. I am trying to install the same version of windows on a new ssd. Edited 3 minutes ago Link to comment Share on other sites More sharing options...
