[Ri...] Posted yesterday at 11:51 AM Share Posted yesterday at 11:51 AM (edited) I am undergoing a path change for our Autorun programs, the path before was about 7 subfolders deep and will become 3 subfolders deep. Example: C:\Zeiss\Company Name\Programs\Another sub folder\Another sub folder\And another sub folder\Geezus\PCM Programs Will now be: C:\Inspections\PCM Programs I came up with the idea of editing the paths in the arn file, this was easy to do. Then I set my Calypso default paths accordingly in settings. When I opened the new Autorun arn file, all the paths were exactly as original, I confirmed the edited the paths in the arn file. Regardless of the path edits, I had to manually change all the paths in the Autorun system, which is a cumbersome task when you have 100's upon 100's of programs in different layers. Where else are the paths being saved for Autorun arn paths? There has to be another file or more to look at. Edited yesterday at 11:53 AM 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted yesterday at 01:02 PM Share Posted yesterday at 01:02 PM Inside of AutoRun - go to Edit - Replace paths for Measurement Plans. There is a much more effective way of quickly changing folder structures. 🙂 2 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted 23 hours ago Author Share Posted 23 hours ago I have found using that interface was hit or miss. I have created the change and Clicked on the Check Mark and watched nothing change. This is why I attempted editing the arn file. 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted 22 hours ago Share Posted 22 hours ago I'll look into this - i think it may be same like with tolerance files - whole Calypso needs to be restarted. Perhaps just closing autorun can help. But i'll see tomorrow. Link to comment Share on other sites More sharing options...
[Th...] Posted 21 hours ago Share Posted 21 hours ago There shouldn't be any other path locations. I have manually edited the arn file before in addition to the path replacement tool without issue. I even made a copy of my arn file just now to change one arbitrarily as a test and confirmed that the change carried over to Autorun. Link to comment Share on other sites More sharing options...
[Ma...] Posted 4 hours ago Share Posted 4 hours ago In ARN file there is this [PATH :\inspections\Program 1] And also this [PARAMETERS :add: (#path -> 'C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\inspections\Program 1'); So i think that "PARAMETERS" is more important than "PATH" Link to comment Share on other sites More sharing options...
