[St...] Posted 3 hours ago Share Posted 3 hours ago Ich benötige Hilfe bei der Umsetzung einer Lagen- bzw. Schnittpunktmessung an einer schrägen Fläche. Das Breitenmaß von 3,8 mm muss dabei fest definiert sein. Anschließend möchte ich ermitteln, an welcher Längenposition sich dieses Maß befindet. Link to comment Share on other sites More sharing options...
[Ma...] Posted 3 hours ago Share Posted 3 hours ago Is it diameter or box? You can make theoretical plane or cylinder and make intersection - use 3.8 as nominal and you will get correct reading for 9.6 Link to comment Share on other sites More sharing options...
[St...] Posted 3 hours ago Author Share Posted 3 hours ago It is a cylinder with a sloped surface on one side. I tried to create a theoretical plane, but I think I’m doing something wrong and could use some help. Link to comment Share on other sites More sharing options...
[Ma...] Posted 3 hours ago Share Posted 3 hours ago So 4° is a plane? Then make theoretical plane at center and perpendicular to 4° plane - their intersection will create a line. Then make another theoretical plane at half of 3.8 and make another intersection with this line to get a point. Link to comment Share on other sites More sharing options...
[Ch...] Posted 2 hours ago Share Posted 2 hours ago Moin Stefan, kannst Du einen Kegelmessen an der stelle? Wen ja mit dem Element Kegelzusatz, findest Du unter "Verknüpfen" Link to comment Share on other sites More sharing options...
