[To...] Posted August 25 Share Posted August 25 I went to use our Contura this afternoon, and it kept cutting the drives off with the 617 Safety Module error. From what I have read online it may have something to do with the air pressure on the back of the CMM. I adjusted it a year or so ago and adjusted it to be above 5.10 today and it is still kicking the drives off. What is the highest I can set this number or is it another issue all together? Any assistance would be appreciated. Link to comment https://qualityforum.zeiss.com/topic/27284-contura-617-safety-module-error/ Share on other sites More sharing options...
[Ch...] Posted August 26 Share Posted August 26 Hi Tommy, I think the inlet pressure is higher—around 6—but what does it say on your label or in the manual? Link to comment https://qualityforum.zeiss.com/topic/27284-contura-617-safety-module-error/#findComment-154754 Share on other sites More sharing options...
[Lu...] Posted August 26 Share Posted August 26 Hi Tommy, This error usually indicates a hardware issue. I would recommend contacting your local support line (if you haven't already) to have a hardware ticket created. Make sure to include the serial number of the machine in question. Thanks! Link to comment https://qualityforum.zeiss.com/topic/27284-contura-617-safety-module-error/#findComment-154810 Share on other sites More sharing options...
